12 years agoAltera SDK 12.0
Hi, Does anyone know where I can get the Altera OpenCL SDK version 12.0. I am using a Stratix IV FPGA and it is not supported by Altera 12.1sp or 13.0. Regards.
Ensure that you use the moving average for 12.1 SP1 and not a newer one since the flow changed significantly at 13.0. Before running the host application I would double check to make sure the board is enumerated properly in the device manager.
If you are powering the board using the PC power supply try switching to the supply Terasic ships with the board. Some machines power cycle the PCIe slots which will wipe out the FPGA causing it to not be enumerated at boot time. So by powering it with the seperate supply you can ensure it remains powered on.
