10 years agoaltera_sc_fifo problem - invalid first transfer
Hello everyone! I am developing design, which includes Altera's Single Clock FIFO implementation. Unfortunately it doesn't seem to work properly. In my earlier projects valid transfers to...
10 years agoActually - looking at your (small) picture and testbench code - I bet it's a delta race problem. Initial block uses# time intervals and is not synchronous to the clock - so the out_ready signal is actually 1 when the clock changes and hence you lose the first word. Change the control initial to use clocks instead of# timing statements:
task wait_for_clk(int n = 1);
for(int i = 0; i < n ; i++) @(posedge clk);
endtask
initial
begin
clk = 1;
resetn = 1;
fifo_data = 64'haaaaaaaaaaaaaaaa;
fifo_empty = 0;
fifo_startofpacket = 0;
fifo_endofpacket = 0;
out_ready = 0;
fifo_valid = 0;
# 30
resetn = 0;
# 50
resetn = 1;
//resyncrhonise to the clock
wait_for_clk(4);
fifo_valid = 1;
fifo_startofpacket = 1;
wait_for_clk;
fifo_data = 64'hbbbbbbbbbbbbbbbb;
wait_for_clk;
fifo_data = 64'hcccccccccccccccc;
wait_for_clk;
wait_for_clk;
fifo_data = 64'hdddddddddddddddd;
fifo_endofpacket = 1;
wait_for_clk;
fifo_valid = 0;
wait_for_clk(5);
out_ready = 1;
end
