dsun01
Contributor
3 years agoaltera_reserved_tck in timing analysis failure
Dear Intel Support/Expert,
I am compiling hip_a10gx_g3x8_avmm_dma256_1602 with Quartus Prime Pro 21.3. after update the IP and minor tune up, it compiles. but it has few timing analysis failures. ...
ak6dn
3 years agoI routinely include these commands in my .sdc file to mitigate timing paths related to the system clock and the JTAG clock:
# setup JTAG clock set_false_path -from [get_ports {altera_reserved_*}] -to CPUCLK set_false_path -from CPUCLK -to [get_ports {altera_reserved_*}] create_clock -name altera_reserved_tck -period 40 {altera_reserved_tck} remove_input_delay [get_ports {altera_reserved_tdi altera_reserved_tms}] set_input_delay -clock altera_reserved_tck -clock_fall 3 [get_ports {altera_reserved_tdi altera_reserved_tms}] remove_output_delay [get_ports {altera_reserved_tdo}] set_output_delay -clock altera_reserved_tck 3 [get_ports {altera_reserved_tdo}] # Cut off paths between async clock domains remove_clock_groups -all set_clock_groups -asynchronous -group {CLOCK_50} -group {CPUCLK} -group {altera_reserved_tck}
