ASWATHYV_V_11
5 years agoALTERA QUARTUS II
Hai,
** Error: C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/INTEG NODE TOP MODULE 6JAN2021/INTEG_TOP_MODULE.vhd(234): Signal 'wrfull_sig' must have only one source since it is connected to buffer...
- 5 years ago
May I know what is the software edition (Pro/Standard/Lite) and version you are using? Kindly try to run the compilation using the latest version of the Intel Quartus Prime software. If the problem persists, you may share the design QAR file for investigation. To generate the design QAR file, click on Project > Archive Project > Archive.
KhaiY
KhaiChein_Y_Intel
5 years agoHi,
Could you share the design QAR for investigation?
KhaiY
