11 years agoHi, this Bug seems to be an old one as you can see in this Thread http://www.alteraforum.com/forum/showthread.php?t=42975, maybe the Solution that is given there helps you, unfortunately it didnt helped me. :cry:
When i came to that point, i started my own Thread http://www.alteraforum.com/forum/showthread.php?t=46673 , without Answers :confused: so maybe we can find here a solution that works for all. Im running on Windows 8.1 and when i try to instantiate the [Altera pll core] the Megawizard starts and then disappear without any error messages, in qsys the whole application closes. I start Quartus in Windows 7 compatibility Mode and then i can see a Message while including the pll to the project: [14736Error Wizard "Altera PLL v14.0" cannot be launched] While this happens, 2 Error-Log Files where generated in the Altera Directory called [hs_err_pidxxxx.log] with this : [A fatal error has been detected by the Java Runtime Environment: ... alot of content is attached in both files ...] I uninstall the java application and the java development kit, uninstall the Altera Software and start a new try with the latest release but it wont work. The next step was to rebuild the jre64 directory which comes with the altera software with the latest java release, without an improvement :( . On a fresh Windows 7 VM everything works fine, but that cant be the solution for that problem, and a rebuild of my system isnt an option for me.
