11 years agoI'm having pretty much the same problem on one of two computers, both in Qsys and from the IP Catalog.
On one computer trying to add the component in Qsys simply causes qsys without warning. On the same computer if I try to do it from the ip catalog I get the same as you show in your image, only the loading bar just vanishes after a couple of seconds and nothing happens. On the second computer both Qsys and the IP catalog work fine. It doesn't seem to be affecting any other ip component in either, just the Altera PLL one.
