14 years agohi all,
I have to connect an asychronous SRAM, the Address to Data valid (read cycle) is 12ns. I want to check the path delay: address_register -> SRAM_ADDRESS pins -> device 12ns tpd -> SRAM_DATA pins -> data_register will be lower than 20ns (2 cycles of my sys_clk). 1. how I define the output address pind to input data pins delay (12ns of the sram)? 2. how I ask the SDC to check the delay of the path I described? thanks alot, Eli
