16 years agoHi
In a simple project, derive_pll_clocks set sram_clk inst|the_pll|the_pll|altpll_component|pll|clk[2] create_generated_clock -name {sram_clk_pin} -source inst|the_pll|the_pll|altpll_component|pll|clk[2] -offset 0.500 [get_ports {sram_clk}] set_clock_groups -exclusive -group [get_clocks {inst|the_pll|the_pll|altpll_component|pll|clk[0]}] -group [get_clocks {inst|the_pll|the_pll|altpll_component|pll|clk[2]}] I got some warning message about unconstrained path. So I have to add the following line to get rid of the warning message. set_clock_groups -exclusive -group [get_clocks {sram_clk_pin}] -group [get_clocks {inst|the_pll|the_pll|altpll_component|pll|clk[0]}] The confusing thing is that the TimeQuest should be able to know that any paths related to inst|the_pll|the_pll|altpll_component|pll|clk[2] are independent of inst|the_pll|the_pll|altpll_component|pll|clk[0]}] by setting clock groups the first time. Why should I set clock groups twice? Many thanks.
