16 years ago --- Quote Start --- Did you configure the FPGA board first, with the Quartus programmer? --- Quote End --- Hi, yes I did program the FPGA Cyclone II first, using the generated file light_time_limit.sof (it is though strange that why is there a "_time_limit" at the back of the file since my project name is just "light"). Is it due to the abnormal .sof file? I am using the manual which is written for Quartus II 5.0; however, I am using Quartus II 9.0, it is said the any version higher than 5.0 should work properly. But there are several difference indeed, I am wondering if it is because of the different versions of software that I am using? thank you
