16 years ago --- Quote Start --- @grit, 1) did you install NIOS IDE ? 2) did you install NIOS IDE in a path that does not contain blank characters or foreign language characters (such as Chinese or so...)? A path such as "C:\Program Files\" is not a good place to have NIOS IDE installed as cygwin does not deal with these characters well. 3) do you have an other cygwin installation running? e.g. cygwin as such or cygwin from the Xilinx EDK? --- Quote End --- 1) yes 2) maybe this is the problem.. let me try to reinstall the NIOS IDE to another path without space 3) sorry that i don know what cygwin is~ probably it is the second situation..thanks a lot! let me try re-install
