18 years agoI used LCELLs as inverter-buffers to create an RO. To analyze the delays I have left the chain open, and I am just studying the propagation delay of the chain. I plan to sample at 100MHz, so I want my osc to run at 10MHz. For this I need to calculate the number of invs I would need.
Here's the VHDL. Hacked Rysc's code from earlier in this thread. *** USE IEEE.STD_LOGIC_1164.ALL; LIBRARY IEEE; ENTITY osc IS PORT ( din: IN STD_LOGIC; dout, pin0, pin1, pin2 : OUT STD_LOGIC ); END osc; ARCHITECTURE arch OF osc IS SIGNAL in0, in1, in2 : STD_LOGIC; SIGNAL out0, out1, out2 : STD_LOGIC; COMPONENT LCELL PORT ( a_in : IN STD_LOGIC; a_out : OUT STD_LOGIC); END COMPONENT; BEGIN in0<= NOT din; LC_0 : LCELL PORT MAP ( a_in => in0, a_out => out0); pin0<=out0; in1<=NOT out0; LC_1 : LCELL PORT MAP ( a_in => in1, a_out => out1); pin1<=out1; in2<= NOT out1; LC_2 : LCELL PORT MAP ( a_in => in2, a_out => out2); dout <= out2; END arch; *** 3 inverter-buffer LCELLs. Compiles well. Ignore LCELL buffers is off. Here's the RTL view. Looks like I wanted it to be ~ link (http://img132.imageshack.us/img132/8985/delaychainzd1.gif) [One odd thing is that the net name and the buffer names are the same? LC_0 appears in nets and buffers both] Here's the waveform vector file ~ link (http://img403.imageshack.us/img403/2221/vvfiw6.gifhttp://img403.imageshack.us/img403/2221/vvfiw6.gif) I run the simulation - this is what I see ~ link (http://img169.imageshack.us/img169/93/simulationtu2.gif) Notice how changes on pin0 occur after nearly 10ns. But pin1 and pin2 change so very fast. In an earlier code, dout transitioned even before pin0 and pin1 would. I am zapped. Am I doing something dreadfully wrong? How can I calculate the propagation delay :S ?
