18 years agoIt's not the cleanest code(a for-generate might work better), but it does do what you want. The instance names should be assignable too. Open the Assignment Editor, type LC_a in the To column, type Location in the Assignment Column, and then X5_Y5 in the Value(or whatever lab location you want), and you can assign to an individual node if you want.
You should also be able to put them all into a LogicLock region, so the fitter chooses their final placement within a lab and where the lab goes, but will keep them all in the same lab. LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY delay IS PORT ( din : IN STD_LOGIC; dout : OUT STD_LOGIC); END delay; ARCHITECTURE arch OF delay IS SIGNAL a, b, c, d, e, f : STD_LOGIC; COMPONENT LCELL PORT ( a_in : IN STD_LOGIC; a_out : OUT STD_LOGIC); END COMPONENT; BEGIN LC_a : LCELL PORT MAP ( a_in => din, a_out => a); LC_b : LCELL PORT MAP ( a_in => a, a_out => b); LC_c : LCELL PORT MAP ( a_in => b, a_out => c); LC_d : LCELL PORT MAP ( a_in => c, a_out => d); LC_e : LCELL PORT MAP ( a_in => d, a_out => e); LC_f : LCELL PORT MAP ( a_in => e, a_out => f); dout <= f; END arch;
