13 years ago
altdpram with NUMWORDS = 1
I all,
I tried to instanciate an altdpram with NUMWORDS => 1 and WIDTHA => 1.
According to http://quartushelp.altera.com/11.1/mergedprojects/hdl/mega/mega_file_altdpram.htm this is OK:
Parameter ; Type    ; Required ; Description
NUMWORDS  ; Integer ; No       ; Number of words stored in memory.
                                 This value must be within the range
                                 2^(WIDTHAD - 1) < NUMWORDS <= 2^WIDTHAD.
                                 If omitted, the default is 2^WIDTHAD.
I get the following error:
--- Quote Start ---
Error: Assertion error: Value of NUMWORDS parameter requires 0 address lines, but WIDTHAD value, which defines the number of address lines, is 1
Error: Can't elaborate user hierarchy "altdpram:ram"
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 2 errors, 494 warnings
Error: Peak virtual memory: 1594 megabytes
Error: Processing ended: Thu Jun 28 09:43:13 2012
Error: Elapsed time: 00:02:23
Error: Total CPU time (on all processors): 00:02:20
Error: Quartus II Full Compilation was unsuccessful. 4 errors, 494 warnings
--- Quote End ---
Has anyone faced this issue?
What can I do?
P.S.:
You may think that it's stupid to instanciate a memory of depth 1.
Actually the depth is generic and may be greater than 1, which is why I need a memory. But I need the system to work even if the user wants a depth of 1.
Thx
Julien
    --- Quote Start ---
    --- Quote End ---
    Mathematically incorrect, isn't it? 2^(WIDTHAD - 1) seems simply wrong.
    Most likely,you need to generate a RAM with NUMWORDS = 2 and map it respectively.
    As an additional observation, I have no difficulties to set NUMWORDS values smaller than (2^widthad-1) with altsyncram, also NUMWORDS = 1 in a direct instantiation of the VHDL component.
    I don't know if there are any differences with altdpram, which it isn't but a wrapper of altsyncram.
