14 years agoDon't do the DDR clock pin. It should work, but painful to do. Instead, have the -source be the physical node of the upstream clock, most likely a PLL output. Look at Case 3 or Case 4 examples in the .zip here, and it will show you:
http://www.alterawiki.com/wiki/source_synchronous_analysis_with_timequest
