9 years agoAltclkctrl ip
I am using ALTCLKCTRL to mux two clock signals. One of the signal is a PLL output and the other one is an from the clock pin. I get an error from the fitter stating that it cannot place a global clock driver between the clock pin and the clkctrl block. I also try to drive the input pins of clkctrl by a clock buffer output (another clkctrl block ; path wold be pinà clkctrl(buffer)àclkctrl(mux)). But it seems that this is illegal. Can someone guide me with this? Thanks, Vittal
