9 years agoAltclkctrl ip
Hi, I am using ALTCLKCTRL to mux two clock signals. One of the signal is a PLL output and the other one is an from the clock pin. I get an error from the fitter stating that it cannot place...
9 years agoAltera PLL and altclkctrl should be different IP. (Although all PLLs drive globals, and the only way to get onto a global is through an altclkctrl, so their "implied" when you put down a PLL and you'll see them in the clock path details of a timing report, but if you want control of it you have to instantiate it, and it replaces the implied one.)
