9 years agoAltclkctrl ip
Hi, I am using ALTCLKCTRL to mux two clock signals. One of the signal is a PLL output and the other one is an from the clock pin. I get an error from the fitter stating that it cannot place...
9 years agoStandard, as Cyclone V is not in Pro.
I believe you launched QSYS, which is for creating avalon fabric systems. The altclkctrl block is not avalon compliant and not available there. It only shows up in stand-alone IP. Go to View-> Utility Windows -> IP Catalog(or click Alt+7) in the main Quartus window, and you should find it there.
