9 years agoAltclkctrl ip
Hi, I am using ALTCLKCTRL to mux two clock signals. One of the signal is a PLL output and the other one is an from the clock pin. I get an error from the fitter stating that it cannot place...
9 years agoHi Rysc,
Are you using the pro version of the software? Or did you activate it separately because I don't see it still. By the way I am using Quartus 16.1 Standard edition for linux. I have attached an image of what I am able to see.
