tfm
3 years agoALT_MULT_COMPLEX is not correct
I was looking for a complex multiplication, and found in the Quartus in IP Catalog, Library/Basic Functions/Arithmetric the ALT_MULT_COMPLEX.
I used it with a enable, let it produce a VHD f...
FvM
3 years agoHi Theo,
I can confirm that the generated VHDL code doesn't compile due to syntax errors, the Verilog code is however syntactically correct.
Regarding usage of 3 multipliers, I'm not sure, but I guess it may be an alternative algorithm to calculate complex multiply. I didnt check the results. Here's the RTL schematic, if anyone knows about the algorithm.
Frank
