HongLiang
3 years agoAlgilex can not generate the programming file in Quartus22.3 pro
we try to create a new project on the AGIB027R31B1I1V
Critical Warning(18636): Compilation Report contains advance information. Specifications for device AGIB027R31B1I1V are subject to change. C...
WZ2
3 years agoYou are getting this warning because the timing models for this device are not yet final. Hence SOF generation also is not enabled yet. If you use the new version quartus it may solve this issue. In the other hands, there is an ini can help you skip this issue to continue your debug process I will email to you.
