alftp components missing in altera_mf_components on Quartus 20.1
- 3 years ago
I came across the same problem today and noticed that the question hasn't been clearly answered by Intel team.
The answer seems quite obvious though. All altfp_xxx IP has been removed from the library since Quartus 19 but is still in the IP catalog for some devices, curiously not for all, e.g. MAX10. As stated in a different thread, it's expected that you use the new HLS based FP_FUNCTIONS Intel FPGA IP instead. It has additional features like freely selecting the pipeline level based on speed requirements.
Frank
Hi Jan,
I received the reply from the team, you may create altera_fp_function in version 18.1 and use that instance in version 20.1. In v18.1, a qip file is also generated which will list all the generated files you need to include in your v20.1 project.
KhaiY
