18 years ago1) Thanks for the information. I was not aware of the "report simulator control" command within ModelSim. Another ModelSim command that be set from a do script is StdArithNoWarning.
2) I haven't found a way around this either. You can, however, undock the waveform window from the main GUI window by using this this command: view -undock wave
