VGopa7
3 years agoAdding Library per file in QSYS component _hw.tcl file
I am working on QSYS (Platform designer) and i need to add few of my IPs in .qsys project.
I created a _hw.tcl for my IP and specified all the required .vhd files in this _hw.tcl. (using "ad...
Ju-Ti
3 years agoThe same problem here.. VGopa7's original question seems to concern naming an analysis labrary for VHDL files. When one of analyzed VHDL files defines a package, and rest of the files refer to that package using a library name, e.g.
library mylib1;
use mylib1.pkgname.xxx;
compilation will fail if Platform Designer / Quartus has analyzed these files to some other compilation library than mylib1. In Component instantiation tab, under Compilation Info, there is a selection for HDL compilation library. However it did not have any effect when I tried it. Also there is an attribute HDL_COMPILATION_LIBRARY but how to use it, is it for this purpose?
https://www.intel.com/content/www/us/en/docs/programmable/683609/22-1/instantiation-properties.html
