13 years ago
Add SignalTap II ,the project won't compilation
Guys:
before i add some signal to the signaltap II ,the whole project compilation is complete , and it work well on FPGA , but after i add some signal to the signaltap the compile came up with error.
the signal i add is a SRAM "wrdata" signal ,the ERROR is like below:
ERROR: Output port 0 of I/O output buffer " pre_syn.bp.Signature_pipe_U_signature_0_~output" must drive a top-level pin
can anyone tell me how to fix this problem? thanks in advance:-P
    May be because you are tapping an output signal
    You can check once by adding a signal which is driving this output to signaltap instead of adding an output signal
    I am not sure but I have seen this error when you do not connect a pin that can be an input and output (i.e can tristate the output) directly to a pin. Maybe signaltap does not like probing I/O pins.
    C
    I've had this problem and it seems that SignalTap cant tap a tristate or bidirectional bus. This may be because the synthesiser converts a bidirectional bus into something else (FPGAs don't really do tristate busses internally) and the pre-synthesis nets don't exist.
    --- Quote Start ---
    --- Quote End ---
    thank you very much ! it helps
