15 years ago
ADC code for Cyclone II DE1 board not working
Hi, i wrote the following code to read digital values from the pins of ADC0804 but it doesnt seem to be working...
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
library std;
use std.standard;
ENTITY ADC IS
PORT( CLK : IN STD_LOGIC;
IN_0 : IN STD_LOGIC;--LSB
IN_1 : IN STD_LOGIC;
IN_2 : IN STD_LOGIC;
IN_3 : IN STD_LOGIC;
IN_4 : IN STD_LOGIC;
IN_5 : IN STD_LOGIC;
IN_6 : IN STD_LOGIC;
IN_7 : IN STD_LOGIC;--MSB
ADC_OUT : OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
END ADC;
ARCHITECTURE a OF ADC IS
SIGNAL ADC_IN : STD_LOGIC_VECTOR(7 DOWNTO 0);
BEGIN
ADC_IN <= IN_7&IN_6&IN_5&IN_4&IN_3&IN_2&IN_1&IN_0;
PROCESS(CLK)
BEGIN
IF (CLK'EVENT AND CLK='1') THEN
ADC_OUT <= NOT(ADC_IN);
END IF;
END Process;
end a;
I tested this code using an 8 bit random number generator and it works fine, but when the cyclone II board is connected directly to the ADC0804, i get no output. The ADC is working fine(tested using array of LEDs)....
What am i doing wrong? please help me guys, this is urgent :(
or is it because of logic voltage levels? ADC0804 = 5V and 0V... Cyclone II FPGA = 3.3V and 0V...
ADC0804 is TTL compatible
Dante
    --- Quote Start ---
    dante: can u help me?how do you do?plzz help me
    --- Quote End ---
    help you with what?
    I see ur adc run rite.. Are u have complete ur Project?? Can u give ur email we discuss it at email
    --- Quote Start ---
    --- Quote End ---
    yes, i completed the project. so i see you want to use ADC0804. there's application note in the ADC0804 datasheet, did you have a look at it?
    Yup i want use it.. Where part in datasheet?? Can u help me. I first time in fpga.. Can u give me cct of adc ??
