15 years ago --- Quote Start --- Got it finally, Thanx Guys:D!!! --- Quote End --- Hi, in case you are using the web edition of Quartus you have to switch on the "TalkBack" feature. This should solve the licence problem. Otherwise you have to disable your signaltap file. You find the setting under: Assignments -> Settings -> Signaltap II Logic Analyzer Kind regards GPK
