14 years agoAdapter for converting Avalon-MM data to Avalon-ST data
Hi, Does Qsys has any component for converting Avalon-MM data to Avalon-ST data. Or can we build an adapter by using Memory Mapped components in Qsys Interconnect. Thanks
8 years agoThank you for your reply. In my system EOP was generated, but the signal tap trigger was wrong, so it was never captured.
Just a note on the possibility of multiple SOPs: The SOP is sent on the first byte of data following the write to the control register at offset 0x1. Even if the control register SOP bit is not de-asserted, the subsequent bytes of data are sent without an SOP. The flow would be as follows: 1. Set the SOP bit (bit 0) at offset 0x1 (Depending on the master and the addressing, it can also be offset 0x4 in your system). 2. Send data by writing the value at offset 0x00. 3. Before sending the last byte of data, set the EOP bit (bit 1) at offset 0x1 (Depending on the master and the addressing, it can also be offset 0x4 in your system). 4. Send the last byte of data by writing the value at offset 0x00.
