14 years agoAdapter for converting Avalon-MM data to Avalon-ST data
Hi, Does Qsys has any component for converting Avalon-MM data to Avalon-ST data. Or can we build an adapter by using Memory Mapped components in Qsys Interconnect. Thanks
8 years agoI haven't used that FIFO but I think you setup the control register for SOP generation, then write your data, then you disable the SOP generation, keep writing data, then on the last beat you setup the control register to generate EOP, then write your data. So generating SOP or EOP requires control information to be written first so you'll need the control slave to be enabled. Once enabled I would take a look at the user guide for that IP core to see what the register format is to control the FIFO. The user manual should be hyperlinked so that when you click on the documentation button with the FIFO GUI open it should automatically bring you to the IP manual.
Also if you set the SOP then send multiple words of data you might end up with multiple SOPs in the stream (probably not what you want).
