13 years agoA/D converter-FPGA-USB
Hello, can anybody provide some basic idea to get digital data from A/D converter(HSMC) into cyclone IVE fpga and pass it into computer via USB port. Thanks in advance
There is also one Verilog example within the CD of daughter card:
module DE2_115_ADDA( //////// CLOCK ////////// CLOCK_50, CLOCK2_50, CLOCK3_50, //////// I2C for HSMC ////////// I2C_SCLK, I2C_SDAT, //////// HSMC ////////// ADC_CLK_A, ADC_CLK_B, ADC_DA, ADC_DB, ADC_OEB_A, ADC_OEB_B, ADC_OTR_A, ADC_OTR_B, DAC_CLK_A, DAC_CLK_B, DAC_DA, DAC_DB, DAC_MODE, DAC_WRT_A, DAC_WRT_B, OSC_SMA_ADC4, SMA_DAC4 ); //======================================================= // PORT declarations //======================================================= //////////// CLOCK ////////// input CLOCK_50; input CLOCK2_50; input CLOCK3_50; //////////// I2C for HSMC ////////// output I2C_SCLK; inout I2C_SDAT; //////////// HSMC ////////// output ADC_CLK_A; output ADC_CLK_B; input [13:0] ADC_DA; input [13:0] ADC_DB; output ADC_OEB_A; output ADC_OEB_B; input ADC_OTR_A; input ADC_OTR_B; output DAC_CLK_A; output DAC_CLK_B; output [13:0] DAC_DA; output [13:0] DAC_DB; output DAC_MODE; output DAC_WRT_A; output DAC_WRT_B; input OSC_SMA_ADC4; input SMA_DAC4; I was not able to add complete code due to following errors: You have included 7 images in your message. You are limited to using 4 images so please go back and correct the problem and then continue again. As I am going to use only one channel out of 4(ADC_DA) for my purpose(Analog to digital conversion), I will map the 14 bit data pins of FPGA with this one. but I am not sure about which other pins like clock, OTR,OEB, etc will be needed for my purpose. For first step i am planning to take the signal from AD converter and display corresponding output into red led like this: library ieee; use ieee.std_logic_1164.all; ENTITY part1 IS PORT ( ADC_DA : IN STD_LOGIC_VECTOR(13 DOWNTO 0); LEDR : OUT STD_LOGIC_VECTOR(13 DOWNTO 0) ); END part1; ARCHITECTURE Behavior OF part1 IS BEGIN LEDR <= ADC_DA; END Behavior; can anybody make me clear.
