12 years agoAccessing SDRAM memory on Terasic DE0-Nano board.
I want to use SDRAM memory located on DE0-Nano board using Verilog (without using Nios). I use http://www.altera.com/support/examples/nios2/exm-avalon-mm.html System placed in the QSYS: htt...
12 years agoI also want to use SD-RAM to store and display a image on a VGA monitor, so if you could post the source files for reading form SD-card i would be really grateful.
Thanks in advance :)
