12 years agoAccessing SDRAM memory on Terasic DE0-Nano board.
I want to use SDRAM memory located on DE0-Nano board using Verilog (without using Nios). I use http://www.altera.com/support/examples/nios2/exm-avalon-mm.html System placed in the QSYS: htt...
12 years agoWhy do you think the SDRAM should contain 'garbage'?
SDRAM is unlikely to contain anything from power up. Try writing a pattern to it before reading it. Regards, Alex
