10 years agoAccessing individual nodes in a bus
Hi How can the individual nodes on a bus be accessed? Is using LPM_DECODE the only way? Thanks
10 years agoIMO the better way is using only HDL and no schematics.
Anyway, in your problem you were close - you can just call the bus CntMod4out[2:0] and then from another wire you can just call it CntMod4out[0] to access bit zero.
