13 years agoDear Dave,
Thank you for your reply. However, I want to reference the path of a separate file (not the TCL script) in order to add it with the add_fileset_file command. Using a path relative to the location of the TCL script would work, but would not be elegant at all since the file to be added is several layers of hierarchy away. I will probably submit a service request with Altera.
