"Access Denied" at the Intel Design Store
They have two displayport designs available ("DisplayPort UHD Scaler and Mixer Design Example" and "Arria 10 DisplayPort 4Kp60 with Video and Image Processing Pipeline Re-transmit Reference Design"), but neither of them is the one I'm asking about. Both of those are retransmit designs, and this one is a TX-only design.
However, I've just noticed that the document describes the process of generating this design manually, I'll attempt that.
Generating it manually is a bit too complicated for my liking (unless I'm missing something). The process is described as follows:
"Instantiate the DisplayPort Intel® FPGA IP ... Click 'Generate Example Design' ... Modify the generated design example by removing the irrelevant blocks from the top-level design and from the dp_core.qsys file.
Remove the RX sub-system, RX PHY top.... instantiate the relevant Video and Image Processing FPGA IPs. ... Connect the CVO II and TPG II Intel® FPGA IP instances ... "
It sounds simple when described like that. The trouble is that there's no top level qsys file. Most of these connections are in the top-level .v file. Therefore, to complete the process, I need to do all these changes (several dozen wires) directly in Verilog.
