14 years ago --- Quote Start --- The reason why I don't/can't generate the programming file is that for some projects, I don't have all the IP licenses and my colleagues does. So getting synthesis and fit done is as far as I can go. --- Quote End --- I see. That is a little frustrating. --- Quote Start --- In an ideal setup, I would definitely want to do everything on my machine before passing the design over to him and his team. Will definitely think about how to streamline this process. Your setup definitely sounds a lot more optimized for Quartus. --- Quote End --- You could use a common virtual machine, or run the Quartus software on a Linux server that you both log into and do your personal tasks. That server would have the IP licenses. Cheers, Dave
