14 years ago --- Quote Start --- Problem is, he and I have separate roles and machines assigned - I do the synthesis and fit on mine, and he generates the programming file for testing. Probably not the most efficient of setups, but essentially it's not his role to re-create and re-run the project on his end. --- Quote End --- Strange setup ... you've gone to all of the trouble to place-and-route, why not just generate the programing file? What 're-creation' is he doing that verifies what you have not already done? If your respective machines are powerful enough, you could both share a common Virtual Machine image; you use it to synthesize and then he uses it to verify. Personally, I use Tcl scripts for synthesis and simulation, and check things into and out of CVS across multiple machines and virtual machines. Other than having a source location environment variable and a build location environment variable, everything is pretty much machine and tool version independent (the build folder is filled with quartus and modelsim directories based on the tool version number). Cheers, Dave
