Yamada1
3 years agoAbout VHDL description
After converting A/D conversion data to 2's complement value, I created float (IEEE754 32bit) conversion, but it does not work well. Float conversion, 2's complement conversion, and peripheral part ...
sstrell
3 years agoYou provide all this info...except what the actual problem is. The code you have there looks fine. What error or warning messages are you getting and what line numbers are they pointing to? Provide that and the code that it's referring to. Whitespace type does not matter.
- Yamada13 years ago
Thank you for answering.
There are some warnings in the compilation result.
As content
Warning (13410)
Warning (15610)
and for pins with fixed outputs or undriven input pins.
Should input pins that have no drive destination be commented out or output to a monitor, etc.?
