Yamada1
3 years agoAbout Timing Constraints
It would be helpful if you could teach us about the following points with the "Set Input Delay" command.
1) In the case of the maximum delay setting, does this mean that the delay value is fitted ...
- 3 years ago
No, as mentioned, set_input/output_delay specifies external delays so the Fitter knows where to place input or output registers to meet timing on the inputs or timing at the downstream device on outputs. set_max/min_delay is a way of specifically saying to the Fitter "I want this path to have a max delay of x and a min delay of y." Both sets of commands affect how the Fitter places and routes things.
RichardT_altera
3 years agoThank you for acknowledge the solution provided.
I’m glad that all your question has been addressed, I now transition this thread to community support.
Thank you.
Richard Tan
