About Timing Constraints
- 3 years ago
No, as mentioned, set_input/output_delay specifies external delays so the Fitter knows where to place input or output registers to meet timing on the inputs or timing at the downstream device on outputs. set_max/min_delay is a way of specifically saying to the Fitter "I want this path to have a max delay of x and a min delay of y." Both sets of commands affect how the Fitter places and routes things.
Thank you for your detailed explanation.
It was very helpful.
Thank you for your prompt response, even though it was an elementary question.
