12 years agoThanks for your help. And this case is only my little example from my all design.
I try to clear this question through Design Compiler in Synopsys, and I have found the way to solve my constraints question. The setup calculate is as follows: Required time: Value(max_delay) - Value(output_delay=3ns); Arrived time: Value(input_delay=3ns) + tdelay; Setup ensure: Arrived time <= Required time So, if I want to constraint the tdelay max 2ns, the result is that we should constraint the max_delay 8ns. set_max_delay 8 -from ina -to outb No matter at all, thanks. Hope we could commucation more latter. --- Quote Start --- I don't see how you found out what the tool is thinking. set_input_delay has nothing to do with tdelay path. It is meant for register path only, so is set_output_delay. And in both cases it has nothing to do with concept of pure delay. set_input_delay is information to the tool about data/clock offset arriving at pins. set_output_delay is information to the tool about allowed range of data/clock offset ejected at output pin. The path of tdelay is comb. from pin to pin and I suppose it will be dealt with independant of register path. Whether you get it or not is up to your luck but still I don't understand the merits of your approach from basic design perspective. May be you tell us what is the purpose of your constraints... --- Quote End ---
