About the "set_false_path" command
- 2 years ago
My apologize for not understand your previous question correctly.
Correct me if I am wrong. This look like asynchronous input to the synchronizer logic.
Setting false path to the [asynchronous input paths to synchronizer logic] (path 1) should be sufficient.
Richard Tan
Should be no problem to use the sdc constraint, if there a problem, you will see the constraint being ignored in the Report Ignored SDC in the Timing Analyzer.
Let me add more info:
The set_false_path command tells the timing analyzer not to analyze a path or group of paths. It can be between keepers (registers, I/Os, etc.) or between clocks.
The -from and -to values are collections of clocks, registers, ports, pins, or cells in the design. If the -from or -to values are not specified, the collection is converted automatically into [get_keepers *]
When the constraint is applied to clocks, then all paths that are clocked by the respective clock will not be analyzed.
Three examples:
# Cut timing from an input port to all of its destinations:
set_false_path -from [get_ports reset_button]
# Cut timing from a mode_select register, which is static in the design, to all of its destinations:
set_false_path -from [get_keepers *|mode_select]
# Cut timing from clk_a to clk_b:
set_false_path -from [get_clocks clk_a] -to [get_clocks clk_b]
The last example cuts timing on all paths where clock clk_a drives the source register and clock clk_b drives the destination register.
Note that transfers in the other direction have not been cut, and another set_false_path assignment would be necessary- set_false_path -from [get_clocks clk_b] -to [get_clocks clk_a]
Cutting timing between clocks is often best accomplished with set_clock_groups.
Richard Tan
Thank you for answering.
I apologize for asking so many questions, but I would appreciate it if you could explain the following points.
1) If a register receives a signal that is completely asynchronous to the FPGA's operating clock, such as a toggle switch, a synchronizer is required. At that time, it is necessary to set a false path between the input port and the first register, but am I correct in assuming that the following description does not cause any problems?
set_false_path -from [get_ports {DATA}] -to [get_pins {reg|datain}
2) Keepers refers to registers, I/O, etc., so [get_keepers *|mode_select] in Example 2 would probably refer to the mode_select register or mode_select port, but if you use the same register as the port name, Does that mean that if there is a name, both parties will be affected?
Sorry for the basic question, but I would appreciate it if you could explain it to me.
