About the concept of "set_output_delay constraint"
- 3 years ago
When you mention 2), I believe this is the question you are referring to:
"2) Depending on the values of tsu_ext and th_ext, the result of the formula may be "output delay max < output delay min", but does that mean there is no problem?"
Yes, it is possible for the setting value of set_output_delay -min to be larger than the setting value of set_output_delay -max depending on the setup/hold time of the downstream device/ external circuit.
If the downstream device has a shorter setup time requirement, then the set_output_delay -min value can be larger than the set_output_delay -max value. This is because a larger delay would be needed to ensure that the output signal meets the shorter setup time requirement.
Conversely, if the downstream device has a shorter hold time requirement, then the set_output_delay -max value can be larger than the set_output_delay -min value. This is because a smaller delay would be needed to ensure that the output signal meets the shorter hold time requirement.
In summary, the setting values of set_output_delay -min and -max can vary depending on the timing requirements of the downstream device. It is important to carefully analyze the timing requirements of the entire system to determine appropriate delay values for each constraint.
Hope that helps to clarify. : )
Richard Tan
Richard Tan
