About Technology Map Viewer
- 3 years ago
1) Yes, you are correct.
2) The two equations are opposite in terms of the input signals because the LOGIC_CELL_COMB module in the left figure (xxx tab) has a negation symbol on its input, and the "F" should only apply to the purple part of the circuit. In fact, these two expressions are equivalent, and the left figure should be used as a reference because its input is the actual input from external signals.
You may also checkout this similar post for further information:
https://electronics.stackexchange.com/questions/353755/synthesis-result-rtl-vs-technology-map-viewer
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
Thank you for acknowledging the solution provided. I'm glad to hear that your question has been addressed.
Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Richard Tan
