Yamada1
3 years agoAbout SignalTap
I'm trying to debug with signal tap, but I can't see the signal as I expected.
It would be helpful if you could give me advice on how to use the signal tap.
I am using Quartus Prime Standard Edit...
- 3 years ago
In most cases, you choose a clock that is in the same clock domain with the signal that you are looking at. But there is no requirement for that. Sometimes you might use a faster clock domain for a slower signal, to get a higher sampling rate.
You can use the fastest clock available to get the best results.
Refer to the Timing Analysis section of the Compilation Report for the maximum frequency of the logic analyzer clock.
RichardT_altera
3 years agoThank you for acknowledge the solution provided.
I’m glad that your question has been addressed, I now transition this thread to community support.
Thank you.
Richard Tan
