11 years agoTry this low-level primitive implementation:
library ieee;
use ieee.std_logic_1164.all;
entity mux_5x1 is
port(
clk : in std_logic;
reset : in std_logic;
sclr : in std_logic;
sload : in std_logic;
ena : in std_logic;
sel : in std_logic;
dia : in std_logic;
dib : in std_logic;
dic : in std_logic;
do : out std_logic
end entity;
architecture rtl of mux_5x1 is
signal d: std_logic;
component dffeas
port (
d : in std_logic;
clk : in std_logic;
ena : in std_logic;
clrn : in std_logic;
asdata : in std_logic;
q : out std_logic );
end component;
begin
d <= dib when sel = '1' else dia;
lc: dffeas
port map (
d => d,
clk => clk,
ena => ena,
clrn => not reset,
asdata => dic,
sclr => sclr,
sload => sload,
q => do
end rtl; The question is of course, why does the Quartus compiler to use this compact implementation? There are at least two possible answers: - many of the signals connected to the DFFEAS primitive are LAB-wide signals, e.g. ena, sload, sclear. They can be only effectively used if more than one LEs is driven by the same signals. - It's known that Quartus can't always find an optimal LE implementation, e.g. using the carry chain for non-arithmetical problems. Examples have been discussed at Altera forum before.
