10 years agoAbout Manual Logic Duplication
Hi, I edit Assignment Editor as follows. Ok sysstate datatouart Manual Logic Duplication sysstate_mld Yes top After placing and routing, I started TimeQuest and the...
10 years agoI guest I got some idea from your reply. However, I still do not know how to realize it by Quartus 2.
Here is the technology map viewer. https://www.alteraforum.com/forum/attachment.php?attachmentid=11438 (1)What should I do to improve the delays between sysstate[0](which fans out a lot) and datatouart[0] by duplication register. (2)When what I want to duplicate is the registers of state machine, sysstate[], which means maybe a lot of other registers it depends(so as it drives), I consider it's difficult to do what you said, duplicating the registers(and any combinatorial logic you need to duplicate) in my source code. Is there easy way to reach it.
