If you're talking about VHDL, then yes / can be synthesised if you use the numeric_std package, but it doesnt allow the pipelining that LPM_DIVIDE gives.
And why dont you show.
1. The modelsim waveform and your code connecting the LPM_DIVIDE. - Altera_Forum
--- Quote Start --- If you're talking about VHDL, then yes / can be synthesised if you use the numeric_std package, but it doesnt allow the pipelining that LPM_DIVIDE gives. --- Quote End --- Thank you,Tricky. I used Verilog HDL, can '/' be synthesised ? My testbench codes is: key_led key1 ( .clk(CLK), .rst(RSTn), .data_in(Dividend), .data_v(Divisor), .data_hun(Quotient), .seg_out(Sout), .bit_out(Bout), .rem(Reminder) ); always @(posedge CLK) begin # 10 Dividend = 123; # 20 Divisor = 10; end endmodule ------------------------------------------------------------- My source .v file is module key_led( clk,rst,seg_out,bit_out,data_in,data_v,data_hun,rem ); input clk,rst; output [7:0] bit_out,seg_out,data_hun,rem; input [7:0] data_in ,data_v; wire done_sig_hun,start_sig_hun; wire done_sig_dec,start_sig_dec; wire [7:0] data_dec,data_uni,data_dec_w; reg [7:0] seg_out,bit_out;// Nixie tube driver ports reg [15:0] scan_cnt; wire dec_clk; assign data_uni = data_in %10; assign data_dec_w = data_in %100; always@(data_hun) begin bit_out = 8'b1111_1110; seg_out = data_hun; end mydiv dv_hun(.denom(data_in),.numer(data_v),.quotient(data_hun),.remain(rem)); endmodule How to use LPM_DIVIDE from Quartus II ? The picture is my waveform at modelsim.
