About Clock Constraints
- 3 years ago
You can just compile to have the timing netlist during (post map/post fit). In Timing Analysis, there should be able to detect the clock you specify in sdc. Also I suggest you to migrate to latest Quartus for better usability and there lot of bug/fix.
Thank you for answering.
I understand that even if Start Compilation is completed up to Timing Analysis, a timing netlist will not be created.
I also checked here, but is the following procedure correct for creating a timing netlist?
1) Start Timing Analyzer
2) Netlist → Create Timing Netlist on the Timing Analyzer
At the stage up to synthesis, the above procedure will also fail with a message telling you to complete the fitting.
It would be helpful if you could also teach us the procedure for creating a timing netlist at the stage of completing synthesis.
I apologize for the inconvenience, but it would be helpful if you could teach me.
- sstrell3 years ago
Are you using Standard (Lite) or Pro? If Pro, you have to have completed at least the Plan stage of the Fitter. In Standard you can create a post-synthesis timing netlist. This is not available in Pro.
