17 years agoYou didn't tell, which device you have been using in your test, but neither the delay nor the rise-times (also of the output signal) are in a range I'm used to with recent Altera devices.
P.S.: You may be able to achieve it using minimum current strength and a high capacitive load, but then you aren't measuring device delays.
