9 years agoa10_ref directory not available in installation
I have downloaded the Altera FPGA SDK 16.0 from download center which is about 20GB. I have installed Pro edition using setup_pro.sh which automatically installs the BSP for the Arria 10 device bu...
9 years ago --- Quote Start --- Actually I checked my own installation of v16.0.2 and apparently the a10_ref BSP was not at all shipped with that version. I think that was because Arria 10 support was still in beta stage. I think my supervisor got the BSP from Altera. You can probably ask Altera directly for the BSP. The BSP from v16.1 will most likely not work since Quartus requires the BSP version to be exactly the same as the Quartus version. --- Quote End --- It works, I've copied Arria 10 BSP from 16.1 to 16.0. At first, it prompted error of version mismatch but after then I changed the version in board's xml and it worked.
